Displays XML target information.
| xml_target_name | Specifies the configured xml notification target. |
N/A.
Use this command to display XML target information.
The following command displays XML target information for all targets:
show log configuration target xml-notification
Following is sample output from the command:
Log Target : xml-notification (sqa) Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Info (through Critical) Log Target : xml-notification (epi) Enabled : yes Filter Name : xmlc_filter_epi Match regex : Any Severity : Info (through Critical)
X670V-48t.1 # sh log configuration
Debug-Mode: Disabled
Log Target : memory-buffer
Enabled : yes
Match regex : Any
Severity : Debug-Data (through Critical)
Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition>
Buffer size : 1000 messages
Percent Full : 60%
Full Alert : None
Log Target : nvram
Enabled : yes
Match regex : Any
Severity : Warning (through Critical)
Log Target : console
Enabled : no
Match regex : Any
Enabled : yes
Match regex : Any
Percent Full : 60%
Full Alert : 90%
Log Target : nvram
Enabled : yes
Match regex : Any
Enabled : no
Match regex : Any
Enabled : yes
Match regex : Any
Percent Full : 100% (wrapping)
Full Alert : 90%
Log Target : nvram
Enabled : yes
Match regex : Any
Enabled : no
Match regex : Any
This command was first available in ExtremeXOS 12.4.
